pulsator delete?
Old Mar 7, 2001 | 12:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
pulsator delete?
I am doing a TPI swap into a g-body.
My sending unit is from a 4.3L Monte. I spliced on wiring from an 88 vette sending unit (TBI pump has diff. wiring)
I used the vette pulsator (friend calls it a "bladder" from the vette unit too.
What does removing it do? Just wondering, based on https://www.thirdgen.org/messgboard/...ML/001636.html
thanks.
Oh... a handy tip on swaps. Get the filter to tank steel & flex lines. Get enough of them and you can reach from the tank to the filter on a longer vehicle w/out running new lines Bending them takes skill to not kink though.
jmd
L69 / T5
Old Mar 7, 2001 | 03:19 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Get rid of the pulsator. Replace it with a piece of high pressure fuel hose. Its just another 'thing' that can go wrong (fall down, bad seal, etc). You don't want to have to drop the tank again.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Mar 7, 2001 | 04:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's some more old messages for you:
https://www.thirdgen.org/messgboard/...ML/000571.html
https://www.thirdgen.org/messgboard/...ML/000586.html
https://www.thirdgen.org/messgboard/...ML/000135.html
Actually if you click on Search at the top right of the screen, and search this forum for Pulsator, you can find all the old messages. The pulsator's supposed to make the fuel pump run a bit quieter... but hey, F-bodies are supposed to be loud! You can buy new ones, too, if you so choose. I should've used the hose...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
