Inline fuel pump for TPI
Old Sep 18, 2007 | 04:36 PM
Basett_Racing's Avatar
I am converting the 350 in my '69 Chevy truck over to TPI. My truck has the original in-cab fuel tank, and I want to use an inline pump. Does anyone know of a good pump that will provide enough psi for the TPI system? TIA!
Old Sep 18, 2007 | 05:03 PM
Guest
Guest
Posts: n/a
Re: Inline fuel pump for TPI
Just about any inline for EFI will work. Needs at least 50psi operating pressure, flow rate more than 30gph. If noise is a concern (they can be quite noisy), find one that has isolation mounts built in. I have a Bosch pump (its for a 928 Porsche, aka the same one Accel and many others sell as a 'performance' TPI external pump) that we used for some years, covered in gas tank filler rubber hose with custom isolation mounts and it was STILL noisy.
Old Sep 18, 2007 | 06:15 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
If you go to www.jagsthatrun.com there is a section on other inline pumps readily available from junk yard cars. It seems like they tell of a half dozen or so. Been a while since I was researching their site.
I used their book and web site to put my first TPI in older car.
Good site.
Ron
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
