Should I convert from carb?
Old Sep 13, 2007 | 04:40 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
This a good deal on a tpi kit?
Never really thought I would be considering this route but... I was wondering if $800 was a good deal for TPI speed density 90-92 kit. This includes a new wiring harness, full intake, fuel pump, distributor, a few of the misc parts needed, and a modified LT1 intake for pre-87 heads (would sell this as I have a set of TBI or more likely vortec heads I'd use)
This would go in my 78 Caprice which I'm currently rebuilding (flooded) so it wouldn't be that hard to put in since I'll have the entire car and motor apart.
Old Sep 18, 2007 | 01:08 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
Re: Should I convert from carb?
SIMPLE ANSWER NO STAY WITH CARB trust me unless you like head aches lol
Old Sep 18, 2007 | 05:51 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Five days later :-P
Bought it on lunch today, since I didn't get this in time. What headaches am I looking at?
Old Sep 18, 2007 | 06:19 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I've done a couple odd ball changeovers like that. You really learn where everything goes for sure. Also, built three streetrods with TPI from scratch. It'll be worth it in the long run.
Go over to www.chevythunder.com and read some about changing out.
You'll need to go over to the DIY PROM section and learn how to edit your eprom data.
The VATS, canister, maybe EGR will have to come out most likely. You get addicted.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
