adding some umph to the LB9
Old Sep 18, 2007 | 04:33 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
disregaurd this post
Old Sep 18, 2007 | 09:46 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: adding some umph to the LB9
You'll have 0 problems the MAF ecm should compensate just fine. I'm assuming this is an 87 up LB9? It has to be for the LT1 cam to work out. The ECM's should be hot enough to run fine with no changes to it. I myself would DEFINETLY port the base and plenum before I dropped the motor in.
*NM I just noticed you said "it's an 87"*
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
