TBI-TPI conversion
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
TBI-TPI conversion
ok im kinda new at this. i have a 1992 camaro with a 305 TBI, i want to change it to a TPI, i know i have to get a wireing harness and an ecm, but can anyone tell me what i need to get or change and what i can keep from the TBI?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TBI-TPI conversion
There is a tech article on this swap, as well as hundreds of posts about it. Good luck and you'll enjoy your new found power once you get the swap done!
Car: 91 Camaro Z28
I am just about finishing up my 91 tbi to 87 tpi maf swap! I had the harness converted by tpiparts.net! I would go there to change over your original harness because you have to repin a tpi to your tbi if you get a tpi one alone! BIG MISTAKE! Most of the swap would use your original sensors which is great for you! the tpiparts.net people know alot and they are very willing to work with you with trouble or questions! I have pics if you need help!
2012sergen11
Oct 13, 2015 07:38 PM
