Help! My computer is going stupid I think...
Old Mar 10, 2001 | 01:01 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have been experiencing a no-start condition on the ZZ4TPI after an extended run. You turn the car off and then try and crank it again, and it turns over, just no start. I thought it might have been something to do with a mis-adjusted IAC. However, it did it too me today. I ground the A and B term of the ALDL together and nothing! (thinking I'd reset the IAC) No blink, no code 12, nothing. After leaving it grounded and turning the key back and forth a few times the computer reactivated and the car started. Is there something in my ignition that is going bad? I have an aftermarket chip so I don't think the VATS is a player anymore. Does the ignition send something to the computer when you turn it on? Any help, this one has me baffled.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 10, 2001 | 01:47 PM
leirch's Avatar
Could it be a faulty ignition module, bad ecm? Maybe ignition cylinder?
I would probly check all of your electrical connections to the computer and anything else in that area. That would be my first thought, don't know what thats worth but hope it helps.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 10, 2001 | 03:22 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Can you hear the fuel pump activate when you first turn on the key? Though a fuel pump generally does not "return" to life, just verify that you can hear the "fuel pump" for the first 2 seconds.
I got a couple of "free starts" with my fuel pump before it totally "bit the dust".
Old Mar 10, 2001 | 08:48 PM
Rob P's Avatar
Engine: ZZ4TPI
You know, I don't remember the fuel pump charging, however, I did check the fuel pressure gage and I had over 30lbs of pressure on the rail during the no start condition.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Mar 10, 2001 | 09:49 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I thought code 12 was supposed to be there. so the comp. would basically be saying hi Im hear!
Old Mar 10, 2001 | 11:45 PM
88 trans-am's Avatar
One time my car had basicaly the same problem. In my case the ecm had taken a crap by holding all 8 injectors open at the same time as long as the ignition switch was on. code 12 dose not always mean that the computor is working. I had this problem for about a month before it wouldn't start at all. That time I played with it for about half an hour and found that I had a crankcase full of gas. It is amazing how much fuel 8 injectours cant pump out in that amount of time. This problem did not show up on the scantool.
Mike s
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
