Svo 24lb
Old Mar 9, 2001 | 08:37 AM
Mike635's Avatar
Svo 24lb
Hi,did a search on the above,and it seems the common agreed upon pressure is 32-36 lbs.This would be set the same as GM injectors? Closed loop at idle with vacuum hose removed and plugged? Thanks Mike
Old Mar 9, 2001 | 11:49 PM
Ski89Z28's Avatar
No, SVO ford injectors are different from GM injectors.
GM injecotrs should be set at 42 psi and can be set up to 50 psi.
Old Mar 10, 2001 | 10:46 AM
Mike635's Avatar
Yes realizing that,but the SVO injectors are set at 32-36lbs at idle?
Old Mar 11, 2001 | 07:31 AM
Ski89Z28's Avatar
Yes.
Old Mar 11, 2001 | 08:46 AM
Mike635's Avatar
Thanks.
Mark_ZZ3
May 24, 2018 01:02 PM
92-Formula
Dec 12, 2015 10:34 PM
Firechicken86
Aug 12, 2015 10:07 PM
Rob P
Aftermarket Product Review
Apr 30, 2001 04:57 PM
