TPI HELP with Pictures!
Old Sep 23, 2007 | 09:59 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
I have some connections and i don't know where they go! Help!!!!!
Old Sep 23, 2007 | 10:21 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Re: TPI HELP with Pictures!
ok pic 1 fuel pump fuse it site by the bat with a cover on it not to sure on the other plug
pic 2 purple wire go to starter along with the other two inline fuse red wires.
pic 3 knock sensor wight and fan temp sensor black knock sensor goes in the block near the oil pain it could be on the p-side or d side most likely the p-side (what year TPI pre 89 i am guessing) temp sensor it between the #6 and #8 spark plug.
The plug near the coil looks like it goes to the bottom of the dusturbuter
The plug near the runners is for the cold start injector witch is really not needed
Old Sep 25, 2007 | 01:38 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
The two vac lines the large one goes to your canister purge and the small one under the plenum to the EGR valve control module. Looks like you could use a shop manual.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Sanjay
Aug 12, 2015 03:41 PM
