car backfires alot when idling down from high rpms
Old Sep 23, 2007 | 10:39 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
For some reson my car will backfire ALOT if I rev it up and let of the gas. Or if I am say holding it in gear and let the engine slow the car down from 3000+ rpms. I know some backfiring is probly normal. But it is rediculess at how much it backfires. I can see flames come out the exhaust!
The car doesnt seem to be running rich i dont think. But the previous ownder did say there was LT1 injectors in it. I am not sure what size differance they are or if it maters.
Mabe timing??
any help would be good people ask me to rev it up all the time (sounds good) but it is imbarssing when i let off the gas and it sounds like a 50 caliber rifle going off!
Old Sep 26, 2007 | 12:19 AM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
Re: car backfires alot when idling down from high rpms
my 91 LB9 did the same as well. i later figured out 3 injectors were stuck open dumping raw fuel in (runnin ***-rich), and my cat was non-existent. the cat should burn off a lot of that unburnt crap, reducing backfire.. start with the injectors, if you have a 305 you should have 19LB injectors and nothing more or less, unless you want to mess with the engine computer. if it's a 350, i think its 21LB injectors stock? i dont know
definitely check into the injectors- get those done first BEFORE the cat, over time the unburnt fuel will plug the cat and render it ****ed
Old Sep 26, 2007 | 05:34 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
stock 305 is 19lb injectors, stock 350 is 22 lbs... anything different from that you NEED to have your prom reprogrammed
Old Sep 26, 2007 | 05:46 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
If your AIR system is still attached, make sure your diverter valve is working. It should divert (vent) air under the hood rather than pump it into the exhaust on deceleration.
An exhaust leak near the front can do it too as it will draw in air on decel and ignite unburnt fuel in the exhaust stream.
Old Sep 30, 2007 | 11:25 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
so the exhaust popping suggest a rich condition or a lean one?
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
