Accel or SVO injectors for stock ROC?
Old Mar 11, 2001 | 04:24 PM
JETHROIROC's Avatar
Should I run the new Accel or SVO 19# or 24# on a mostly stock '90 350 IROC? Thanks guys.
Old Mar 12, 2001 | 11:30 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would recommend an injector which is rated at 22 or 23#/hr flow rate if rated at the GM pressure for any 350 which is mainly stock or mildly modded. Also, you should install an adjustable fuel pressure regulator when you install new injectors. This will allow you to fine tune the engine performance relative to fuel pressure.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Mar 13, 2001 | 09:23 PM
evilho7810's Avatar
I ran ford 24# on my 99% stock (I have an afpr) 91 z28 with a 350 and it runs perfect, passed emissions, and I get about 17mpg in the city about 23-25mpg on the expressway.
Old Mar 13, 2001 | 09:45 PM
JETHROIROC's Avatar
Damn. I figured that the SVO's would work out OK, but I went ahead and ordered the Accels (23#). Same price basically, but the Accels are new so I don't know what kind of track record they have. Anyways, thanks for the response and I'll keep that in mind for future injector considerations.
tazs2000
Jul 15, 2017 08:44 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ezobens
Aug 19, 2015 10:29 PM
marcusaw
Aug 10, 2015 08:13 AM
