TPI Swap I know I know.... Not another one
Old Sep 27, 2007 | 12:57 AM
YelloSchtang001's Avatar
yea another one I would like to swap a tpi motor into my s10 to keep it FI problems is I have Plenum, Sensors and computer I do not have an actual motor to bolt this stuff to my question is should I keep and eye out for for and 85 or newer motor or will any sbc work(55-85)?
Old Sep 27, 2007 | 11:25 AM
Guest
Guest
Posts: n/a
Re: TPI Swap I know I know.... Not another one
Any SBC will work, the only difference you might run across is the bolt angle on the heads vs whats on the intake. 87-up heads are compatible with 87-up intakes. It can be corrected fairly easy, just a FYI.
Old Sep 27, 2007 | 10:19 PM
Vader's Avatar
The other consideration is that a TPI might not be the best match for a half-truck. Unless you're running about a 2.56 gear, the torque range is not optimal for the lightweight truck. I considered that for my Sonoma, but am leaning toward the LT1 instead.
Old Oct 17, 2007 | 12:48 PM
wouldnt the lt1 have the same torque range essentially as a tpi (with the lt just have more tq obviously)
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
