Fuel injector replacement?
Old Mar 14, 2001 | 11:48 PM
JETHROIROC's Avatar
OK guys here's what I have lined out for my injector replacement next week. If you see anything I forgot please let me know:
Accel 23# injectors
Holley AFPR
EGR
EGR gasket
MAT
Fel-Pro plenum gaskets
O-ring set (AC)
Injector retainer clips
Fuel line to rail o-rings
Fuel filter
That's it, am I leaving anything out? Thanks.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires
Hypertech fan switch, hot wife, new oil filter, thick rubber floormats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 14, 2001 | 11:49 PM
JETHROIROC's Avatar
Oh, I almost forgot:
2 12 packs of Pabst Blue Ribbon
2 cans of Skoal
Old Mar 15, 2001 | 12:32 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Why don't you do a little porting to the plenum while you've got it off.
There are tech articles all over the internet.
I plan on replacing mine tommorow. If I find something that's not on the list I'll let you know. So far all I have is the injectors w/ O-rings, AFPR, and plenum gaskets....I already did the fuel filter so I don't need to do that.
Later,
Jesse
85 Z28, 305 TPI A4
pretty stock with MSD and a few other toys
15.2@91mph
http://photos.yahoo.com/j_hougnon
[This message has been edited by oldblueZ (edited March 14, 2001).]
Old Mar 15, 2001 | 12:50 AM
theformula's Avatar
New vacuum lines definitely.
Also, if you ever wanted to swap to aftermarket runners now is the time.
Old Mar 15, 2001 | 09:41 AM
JETHROIROC's Avatar
Thanks fellas. Good ideas.
Old Mar 15, 2001 | 08:53 PM
Vader's Avatar
Jethro,
While you have the plenum off and there is plenty of room, you might want to at least install the wiring for a remote MAT sensor. The whole thing will cost you about 20 minutes and another thirty bucks with a sensor, twenty without.
Check this file:
MAT Sensor Relocation.pdf
You remembered the Skoal and PBR, but you should also add a good quality Torx bit (not one of those with the name of some southeast asian country proudly emblazoned on the side) . And I can't believe you didn't mention a can of Never-Seeze between the brew and the snuff.
Don't forget to crack the distributor clamp bolt loose and coat it with anti seize while you have the space to get a real wrench on it.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 15, 2001 | 11:18 PM
JETHROIROC's Avatar
LOL! Thanks a bunch, Vader. I forgot all about the MAT relocation. My torx bits are Stanley and have held up pretty well so I should be OK in that department (knock on wood). I may need the antiseize for my elbows too .
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
