adjusting/setting fuel pressure
Old Sep 28, 2007 | 06:49 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
ok guys.. here is my dilema. I currently do not have a fuel pressure gauge nor do I know anyone that would lend me one. I've replaced my fuel rail and replaced the adjustable frp with a tpis unit. As per instructions, I tightened the bolt until it contacted the washer and then gave it one full turn. Car runs, but it is pig rich.
My question is does tightening the bolt more increase or decrease the fuel pressure?
Old Sep 28, 2007 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: adjusting/setting fuel pressure
http://www.canadiantire.ca/browse/pr...romSearch=true
Old Sep 29, 2007 | 12:19 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
It will increase the pressure also get a fuel pressure
gauge and do it right
Old Sep 29, 2007 | 02:27 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Correct. You could probably "rent" a fuel pressure gauge from one of your local parts stores.
Old Oct 1, 2007 | 01:40 AM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
Yeah, Checkers/Advance sells them for $60, very useful addition to any modern mechanic's tool box. But they also rent for like $6 a day,you pay in full, then get a refund when you bring it back. On my AFPR I had to back it all the way off to get it down to 44 range.
Old Oct 1, 2007 | 07:41 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I have the tpis unit. Not bad. I got my fuel pressure gauge from DangerZone and it was like $40 for the Actron unit. My AFPR is backed off quite a bit and I'm still at 51 psi. My car likes 55 psi but don't do that if you're stock. No point to it.
Old Oct 1, 2007 | 08:01 PM
Enyce31082's Avatar
Car: 1987 Pontiac Trans Am
ok so if i have a 305 tpi with a flowmaster exhaust 3 inch from cat. how much fuel pressure should i have
Old Oct 3, 2007 | 02:14 PM
Brisk's Avatar
ok I bought a gauge and set my car to 46psi.., seems to respond well at this setting so far. I also found this which helped me do this properly;
The correct method for setting fuel pressure is to:
1) connect the fuel gauge securely with no fuel leak
2) start engine, let engine idle down to proper idle RPM
3) disconnect & plug vacuum line from plenum to AFPR
4) read your fuel pressure.
Stock fuel pressure should be at 43 to 44 psi.
With mods, you might want more than stock fuel pressure. Also, realize that the fuel pressure is set for the correct AFR at WOT, not for idle or for cruizin around.
Old Oct 3, 2007 | 03:26 PM
all4u's Avatar
Car: Firechicken
For enyce31082, all I can say is that with a catback, changing fuel pressure won't do much. Maybe help throttle response a bit but not much more. It's kinda like an airfoil, it doesn't do much to a bone stock or mild modded car, but once you keep adding mods, the airfoil and AFPR does help.
Old Oct 3, 2007 | 03:41 PM
BLACK92B4C's Avatar
Hmm, differing opinions on this one...some sources have claimed up to a 15 RWHP increase by optimizing the fuel pressure on an otherwise stock engine. I certainly noticed a difference in mine.
Old Oct 3, 2007 | 05:21 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
You will only notice a difference if your tune is sub par for your combo. If you burn chips and datalog, changing the fuel pressure is not required because you can get the tune set properly.
Old Apr 27, 2011 | 10:03 PM
Abubaca's Avatar
There's only one "right". If you saw gains, then it WAS wrong, and you made it better. ...beyond that, it's for fine tuning, not really for "performance" so to speak.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
