L31 shorblock Qs
Old Mar 18, 2001 | 03:35 PM
james_fearn's Avatar
L31 shorblock Qs
Is this a good starting point for a build up? are the pistons decent? Any thoughts/experience with it???
I'm looking for a mild and effiecient 350 buildup for the summer time frame complete w/ zz4 cam and TFS 23* heads.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
Old Mar 18, 2001 | 04:00 PM
rangelec's Avatar
I have an L31 in my 86 Z28. The stock pistons are cast and with the stock heads are 9.4:1 comp. The stock vortec heads are very good up to .480 lift and beyond if you change springs. I am using the GM hotcam kit in mine-about 410 hp,430 ft-lbs tq-750 carb, etc. The block is a roller cam block also. The light duty block (1500 pickup) is two bolt main. The medium duty(2500-3500 pickup) is four bolt main. I believe the rods are the PM type with a cast crank-good for 6000 rpm. Mine runs great.
Old Mar 19, 2001 | 12:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
L31 is Vortec? I have a 96 Vortec block in my car. The pistons are hyperuetectic. Aside from having to replace the timing cover with a regular one, and get a fuel pump block off plate, everyone was fine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 24, 2006 | 03:59 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Kevin, did you have to do anything to put that normal timing cover on? I've heard something about drilling a hole or 2 for the timing cover. Also, anyone know anything about the crank on these? I have an L31 stripped bare, the crank was ate up by a spun bearing, and it had a crank sensor with a reluctor plate on the crank. Can I just stick any normal 350 1 piece rear crank in it?
Old Nov 25, 2006 | 03:22 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I bought a new L31 shortblock from summit for 1499.00. It is a 4 bolt roller block, cast crank, PM rods and cast -13 cc dish w/ 4 relief pistons. I added trickflow heads, edelbrock intake/runners, #24 injectors, stock L98 cam w/ 106 rr's. The correct GM roller chain and 16 new gm roller lifters. Mellings oil pump and arp steel oil pump shaft with complete gasket kit. Cost $4000.00 total @ summit. I added a 52mm TB and ported the plenum. I am still running the stock prom and I am reasonably happy with good performance and very good fuel economy ( my reason for the stock cam). Pulls very hard down low, even in a 4000 Jag w/ a 2:88 gear. I will get it tuned next spring.
Attached Thumbnails L31 shorblock Qs-000_0741.jpg   L31 shorblock Qs-000-0467.jpg
FormulasOnly
Jul 23, 2018 08:47 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
sandman92084
Sep 12, 2015 10:27 PM
L98GTA87
Aug 25, 2015 02:23 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
