NOS fuel safty switch on tpi how u plum it?
Old Mar 19, 2001 | 07:44 PM
bad camaro RS's Avatar
where u put it? howd you plum it? where youd get the fittings? thanks
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Mar 19, 2001 | 11:35 PM
98_1LE's Avatar
NOS sells a 45° and 90° adapter fitting that screws onto your schrader valve (pass side fuel rail). These keep the sensor from hitting the plenum. You have to remove the actual valve, it is just like a tire valve (actually physically interchangeable, though I wouldn't swap them). The valve screws out with a standard tire valve tool from any auto parts store.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
