Am I nuts?
Old Mar 20, 2001 | 06:38 PM
Steve R's Avatar
Am I nuts?
Is it just me or are TPI cars faster when you first start them up in the morning?
And if i'm not nuts, how do I keep it going that fast?
Also note that my tranny fluid is brown-ish.. Could it be warming up and allowing the tranny to let go a little?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Mar 20, 2001 | 06:49 PM
SpankuGta's Avatar
Its faster cause the motor is still cold and therefor so is the intake and the air flowing in.If you wanna keep it that fast put a small shot on it.
88 GTA 73k miles
Flowmaster catback,Random tech high flow cat,Ported plentum,Hypertech afpr and air foil,cold air induction,Msd blaster ss coil,cap and rotor and Super Conductor wires.Best ET 1/8th 9.21 at 77 mph.All mods were done within two weeks after purchase.
Old Mar 20, 2001 | 06:53 PM
Vader's Avatar
Steve,
First, and foremost, if you are "going fast" first thing in the morning, you might have determined how the transmission fluid got burned. Change it as soon as you can, and try to get it all out. The torque converter has a drain plug on its perimeter, and can be accessed by removing the flywheel inspection cover.
Second, the likely reason your car feels more powerful when cold is that it is running on a richer fuel mixture. This is common to all EFI systems, and one of the main reasons people try to lower the coolant temperature to more reasonable levels. Check the message archives on cooling yout engine, or check this file:
Cooling.pdf
You'll need Adobe Acrobat Reader to view/print the file.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
