Whats involved in a LT1 swap??????????
Old Mar 20, 2001 | 11:50 PM
LegendSC's Avatar
Just wondering?? I have a pretty much stock L03 TBI and would like to know what's involved in a LT1 swap? I have a parts car, with no wireing harness or tran.????????
Old Mar 21, 2001 | 06:11 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You might want to try the Motor swap board, there should be plenty of help for you there..... https://www.thirdgen.org/cgi-bin/mes...=20&LastLogin=
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Mar 21, 2001 | 08:51 AM
Kyle F's Avatar
To the best of my Knowledge of the LT1 and L98 you would need a complete Longblock LT1 with accesories. The fuel system should be ok. You will need to change the radiator it think because the LT1 has reverse cooling. Ofcourse you will also have to do a complete ECM and wire harness swap. That should be about it, the blocks should mount in the same and the Transmission bell housing should be the same. If not you might have to get and adaptor. Its a lot of work, might be cheaper just to rebuild your L98 or get a 350 block for your current set up and go from there.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Mar 21, 2001 | 11:17 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The stock style radiator (85-92) works great, actually for this and doesn't need changed.
The line which in an f-body that goes from the H2O pump to the lower DS tank can be capped (it is in a vette) the lower hose is tricky, but I believe my friend used an 80-88 Olds 307 g-body hose; the upper, a trimmed 305 80-88 g-body hose. The heater return on the passenger side tank is used.
If going w/ a 4L60-E, get the 4th gen tranny lines; they have flex at the front, making things a tiny bit easier.
Old Jun 22, 2013 | 05:46 AM
Borden88's Avatar
Car: 88 Trans am t-top
Engine: 5.0L 305 TPI looking for a new one!
Axle/Gears: 3.23 i think
Re: Whats involved in a LT1 swap??????????
what exactly do i need fro a 88 tpi swap out to a lt1 which will be bolted to a 700r4
Old Jun 22, 2013 | 05:36 PM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Reading the swap sticky on this subject might help, actually it will help a lot which is why it's a sticky in the first place
Posted from Thirdgen.org App for Android
Old Jun 22, 2013 | 08:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You want the LT1 SWAP DEPT
3rd floor on the left
https://www.thirdgen.org/forums/ltx-...questions.html
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
