Car is dead
Old Jun 20, 2013 | 10:20 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Car is dead
Was driving home from work, turned a corner, car started running like total crap. Backfiring, rough engine, dies. Manage to get it started, still runs like crap, until about 2k RPMs, above that its smooth. Died 3 times on the way home, but I did manage to nurse it home. There is no smoke out the exhaust.
Hooked it up to the scanner, pulling a code 44 (Lean O2). any suggestions as to what it might be? any help would be greatly appreciated.
Praying its a vacuum leak, but knowing my luck, probably not.
Old Jun 20, 2013 | 11:16 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car is dead
Start with checking your fuel pressure.
Old Jun 20, 2013 | 06:46 PM
Veaceonee's Avatar
Re: Car is dead
Cracked the fuel pressure line, fuel sprayed out. Cracked the return line, it leaked. Turned on pump again to "pressurize" , pushed on the shrader valve in the fuel rail- nothing. I am thinking Fuel Pressure Regulator went south.
Old Jun 20, 2013 | 06:48 PM
Engine: Lb9
Transmission: M20
Re: Car is dead
Never done it that way how much spray per psi lol
Old Jun 20, 2013 | 10:47 PM
Veaceonee's Avatar
Re: Car is dead
Changed out the fuel filter. I was expecting some leakage, but it NEVER STOPPED coming out. Finally got it stopped (suffering from 1st degree chemical burns from the puddle of gasoline I was lying in right now). but I think this may be the factory original fuel filter.
Old Jun 20, 2013 | 10:50 PM
Engine: Lb9
Transmission: M20
Re: Car is dead
Doesn't look oem
Old Jun 20, 2013 | 11:35 PM
Veaceonee's Avatar
Re: Car is dead
I am also curious as to why it never stopped leaking/seeping . I removed the gas cap prior to starting.
Old Jun 20, 2013 | 11:38 PM
Engine: Lb9
Transmission: M20
Re: Car is dead
Gravity bleeding
Old Jun 21, 2013 | 04:45 PM
Veaceonee's Avatar
Re: Car is dead
Got it all put back together, no start. Bypassed the fuel pump relay, it sort of started, ran like crap for about 5 seconds then died. There is no residual pressure in the fuel rail (push the shrader valve, nothing comes out). Fuel Pressure regulator maybe?
Old Jun 21, 2013 | 05:30 PM
Engine: Lb9
Transmission: M20
Re: Car is dead
Buy or rent a fuel pressure tester. If there is fuel in the vacuum line to the regulator the regulator would be ripped. Do a few fuel pump primes koeo with a fuel pressure gauge on.
Old Jun 22, 2013 | 05:34 PM
Veaceonee's Avatar
Re: Car is dead
Bought a fuel pressure gauge. Turn pump on-12 psi. Turn pump off- immediately 0 psi.
Old Jun 23, 2013 | 07:12 PM
Veaceonee's Avatar
Re: Car is dead
Put a new fuel pump in. Car now runs. O2 levels are all over the place and it has a miss. Oh well, the fun never stops.
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
