ecm code info
Old Mar 22, 2001 | 09:24 PM
bowtiez's Avatar
ecm code info
Does anyone have specific code #'s and what each is for on a 85z28 305 tpi 700 tra. My Haynes must be wrong. Were there changes due to model's in 85
Old Mar 23, 2001 | 04:26 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Here you go
TROUBLE CODES
12. No reference pulses to Electronic Control Module (ECM).
13. Oxygen sensor signal stays lean during warm engine cruise
14. High temperature indicated at engine coolant temp. sensor
15. Low temperature indicated at engine coolant temp. sensor
16. High battery voltage OR Direct inition system open or shorted to ground
17. RPM signal problem
18-20. N/A
21. High voltage at throttle positon sensor
22. Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground 23. Low temperature at manifold air temperature sensor OR Throttle position sensor error
24. Circuit fault in vehicle speed sensor
25. High temperature at manifold air temperature sensor OR Vacuum switching valve circuit open or shorted to ground OR High voltage at ATS sensor
26. Fault in quad driver module
27. Fault in 2nd gear switch
28. Fault in 3rd gear switch
29. Fault in 4th gear switch
30. N/A 31. Low voltage at manifold absolute pressure sensor OR Fuel injector OR Park or neutral switch OR CAM diagnostic OR Governor malfunction OR Wastegate overboost OR Wastegate eletrical signal open or shorted to ground
32. Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch or Fault in electronic vacuum regulator valve
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35. Idle speed can not be set to desired RPM
36. Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal
37. N/A
38. Fault in torque converter clutch brake switch
39. Fault in torque converter clutch circuit
40. N/A
41. Fault at cam sensor OR Cylinder select error OR Tach input error
42. Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
44. Oxygen sensor lean
45. Oxygen sensor rich
46. Fault at vehicle anti-theft sytem OR fault at power steering switch
47. Problem at Electronic Control Module (ECM)
48. Misfire
49. Vacuum leak
50. N/A
51. PROM error
52. Problem at Electronic Control Module (ECM) - Missing fuel calpac missing OR Analog to digital converter error OR Fault at quad driver module OR Low voltage at oil temperature sensor
53. High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error OR Problem at vehicle anti-theft system
54. Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
55. Problem at Electronic Control Module (ECM) - ECM failure OR Serial bus error OR Fuel lean malfunction
56. Low coolant or corrosivity OR Fault in port throttle system vacuum sensor
57. N/A
58. Problem at vehicle anti-theft system 59-60. N/A
61. Oxygen sensor degraded OR Port throttle system error OR Cruise control problems 62. Gear switch input diagnostics OR High voltage at oil temperature sensor OR Fault in cruise control- vacuum solenoid circuit 63. High voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Fault at right oxygen sensor
64. Low voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Right oxygen sensor lean
65. Failure at exhaust gas recirculation valve OR Faulure at injector peak/hold diagnostic OR Right oxygen sensor rich OR Fault at cruise control position sensor
66. Internal reset of Electronic Control Module (ECM)
67. Fault at cruise control switch
68. Fault at cruise control switch
69. Fault at air conditioner pressure switch
70-87. N/A
88. Internal reset of Electronic Control Module (ECM)
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Billy Decker
Sep 4, 2015 03:46 PM
RyanJB
Sep 2, 2015 01:27 PM
