question abut KN filter for 85 trans am, the one that eliminates air box.............
Old Mar 25, 2001 | 04:01 PM
ONEFINE8T9's Avatar
i was looking through the jegs online catolog and i saw the sweetest thing. It was a KN filter that came directly off the TB and eliminated the air box. I so want this part but one problem......it says will not work on MAF car unless converted to SD. My question is, why cant i use this on a MAF car? is there one available for maf cars? I dont wanna change to SD for the sake of an air filter but i really like this part and if there is on available i will get it. thanx in advance-Mike
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Mar 25, 2001 | 06:21 PM
89FormulaL98's Avatar
No you cant do it because you are not only eliminating the air box, you r also removing all if the tubing between the air box and the throttle body. the MAF is located between the air box and the throttle body, therefore u would be removing the MAF by getting an air filter like that. You engine will run very rich with out the MAF
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
more to come soon.....
My temporary P.O.S. website: www.angelfire.com/il3/DuPageSpeed
Old Mar 25, 2001 | 06:30 PM
ONEFINE8T9's Avatar
damn that really sux, that thing really would look nice under the hood. I am assumeing there isnt one available that will work? Maybe something that will give u a maf relocaeing kit? that seems like alot of BS though for an air filter. maybe ill just get the OEM style K&N
Old Mar 25, 2001 | 06:37 PM
mrls199's Avatar
Hey try slponline.com they have somethink like that for maf or sd cars
Old Mar 25, 2001 | 08:08 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
y not try and rig up a K&N cone filter to your MAF?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 25, 2001 | 10:47 PM
rondubbs's Avatar
put a k&n in the stock air box and run tubing underneath the car to pick up cold dense air = homemade cold air induction really cheap,,dont waste your money on slp or any other companys kit.. that tb filter will only pick up hot air from under the hood, you cant use it anyway on maf cars. check out the tech section for some cold air induction ideas
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
maroe624
Apr 16, 2017 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
