is anyone running a ZZ9 cam in an LB9
Old Mar 27, 2001 | 11:13 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I am wondering if there will be any real issues to deal with trying to run the ZZ9 cam in the LB9...
thanks,
Chris
Old Mar 27, 2001 | 12:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, piston-to-valve clearance, and coil bind. You'll have to change the springs on the heads, and you might have to machine the heads to accept the springs.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 28, 2001 | 06:07 AM
Nitro Don's Avatar
Im running a comparable cam inm a 305.
Comp Cam 210/220 .533/.544 114 lsa
Im using WP 305 heads.There is no problem with piston to head clearance,but springs are a big issue now.Mainly,the tops of all the exhaust springs broke off.
Spring pressure,coil bind,and installed hieghts are really important when dealing with high lift cams.
Nitro Don
Old Mar 28, 2001 | 09:03 AM
1BADAZTA's Avatar
Hey Chris84TA, you shouldn't have a problem with the cam working, but the springs on the heads probably will, if there're stock heads.Why don't you replace the heads while you're already there. WP Torquer 305's are nice and fairly cheap. Just so you know, I also have a 305 and I have an SLP cam with a 218I 224E@114 lobe seperation, I do have the WP Torquer 305 heads though as I'm sure that made a difference, with no binding or other problems as I had them build with decent springs already. Good luck.
88'TA 305TPI 330HP, NATURALLY ASPIRATED, PASSES N.J. EMMISIONS. "I AM JUST THAT GOOD"
Old Mar 28, 2001 | 09:58 AM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
well... i was thinkin bout putting the ZZ9 in when Scroggin finally gets that intake for vortec heads finished...
the setup will be backed by a WCT5 in an 84TA...
i will have a 5spd conversion under my belt in a few weeks so i will know better what to do the next time...
i am getting a complete '88 LB9/5spd setup... so my ttop car should be fairly well equipped...
my vert is an L69 car... and is getting a T5...
later,
Chris
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
