1.6 rockers is a good deal?
Old Mar 27, 2001 | 03:51 PM
pontiac's Avatar
i just compared few aftermarket cams and noticed that i could have almost the same cam with high ratio rockers...
GTA's stock cam 10066049
duration: 207/213
lift with 1.6 ratio: .443/.459
lobe: 117deg
Crane 104121
duration: 204/214
lift with 1.5 ratio: .429/.452
lobe: 116deg
SLP 51002
duration: 206/214
lift with 1.5 rockers: .470/.490
lobe: 112deg
Competition Cams 08-300-8
duration: 206/210
lift with 1.5 rockers: .450/.480
112deg
what kind of rockers i need? stock valve springs are ok? computer likes it? would it be just simple bolt on thing? anyone tryed it to 350 TPI?
-p
Pontiac Trans Am GTA'89
CC1 GW6 G80 JG1 L98 MXO N64 WS6 822
Old Mar 28, 2001 | 12:49 PM
Scubaguy's Avatar
I also would like to know about changing the rockers, I have to do my valve seals anyways so while the rockers are off I was thinking of going to a 1.6 ratio with a roller tip.
Does anybody know if this would be worthwhile?
Mark
1988 Trans-am GTA, 5.0l, TPI, T-tops, Mac STB, Mac SFC's,
K&N Filtercharger, Vortex Cat Back
Best e.t. 15.48 @ 88.26 MPH
Member of Toronto F-Body Motorsports http://www.tfbm.org
my car page http://www.fortunecity.com/silversto...5/carspage.htm
Old Mar 28, 2001 | 02:48 PM
irocbob89's Avatar
i think the stock heads are ok up to about .500 lift, i dont think you will be going over .500 lift with 1.6rr and a stock cam.
i have some 1.6rr for sale comp cams roller tip rockers 3/8 stud (not sure what stock studs are?) roller tips $100 shipped
Bobby
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Old Mar 28, 2001 | 03:57 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
The lifts of the cam may be the same when you add 1.6's to the stock cam, but the overall profile is probably much different. You have to take into account how fast the valve is opened, which is affected by the ramp. Faster, the better, but harder on the valvetrain. LSA makes a difference, too.
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
midge54
Dec 27, 2019 04:14 PM
LT1Formula
Aug 20, 2015 09:36 PM
IrocZ'85
Aug 17, 2015 06:24 PM
happyhapka
Aug 15, 2015 04:42 PM
ChevyZ71
Aug 13, 2015 07:30 AM
