Injectors too big?
Old Mar 29, 2001 | 12:05 PM
MY87GTA's Avatar
Injectors too big?
How do you know if your injectors are to big for your car. Not knowing what is truley done to my car, i was wondering if my injectors where too big and maybe this would cause some sort of a idle problem, which i seem to have. What is too big for a 350 TPI? What injector size is stock on 350 TPI?
Old Mar 29, 2001 | 12:51 PM
theformula's Avatar
22lbs is stock for your car. How do you know your injectors aren't stock? What else do you have done to the car? Do you have a custom prom? Have you viewed your car under a scanner? At what temperature does it go into closed loop? Does the problem go away in closed loop?
Some things to think about. You may be looking at some prom work, or a 3 wire heated 02 sensor.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
