Quick question about cold start inj.
Old Mar 29, 2001 | 03:42 PM
F22Raptor's Avatar
Hey guys, I hear that you can disable the coldstart by removing the 3amp fuse (crank). My question is, can I cut the wires going to the coldstart inj.? I just hate unnecessary clutter.
Thanks, Rick
Old Mar 29, 2001 | 05:10 PM
leirch's Avatar
I would just remove the entire cold start injector and anything that has to do with it. Then just plug the hole it used. Alot cleaner and you will even clear up more clutter.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 29, 2001 | 08:43 PM
F22Raptor's Avatar
Cool....thanks
Wade787b
Sep 29, 2015 01:15 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
