irratic idle??? HELP!!!! PLEASE!!!!!!
Old Mar 30, 2001 | 12:02 AM
craiger's Avatar
I have no idea what is going on with my car? My idle is running between 1500-1700rpms and caughing ( droping 400rpms ) and then jumping up and down between 1500-1700rpms. My vacume is at a steady 20in and no movement of the needle at idle. When i put the car in drive it seems to run fine but when in park at a stop light the car jumps or caughs from 1200rpms to 700rpms and runs irratic? HElP. PLEASE
Craig
Old Mar 30, 2001 | 01:09 AM
Phantom_Z's Avatar
I would say it is the pick ups in your control module on the distributor, mine did the same thing until I changed the control module.
87' TPI 305 5-speed Z28, Bolt ons, weld wheels, front runners, complete audio system, cowl hood, custom paint with phantom racing stripes
http://www.blazeracing.com
Old Mar 30, 2001 | 01:45 PM
leirch's Avatar
IAC, TPS? Have you adjusted them lately? Maybe fully cleaned them out? General tune up?
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
