Cold Low RPM Miss
Old Mar 30, 2001 | 05:30 PM
TPICherokee's Avatar
Cold Low RPM Miss
Here's the problem: When my 305 MAF motor is cold it starts and runs okay but when I start to go it has a horrid miss, but once I get above about half throttle the miss magically disappears until I let off again. When the vehicle is warmed up it doesn't do this. I replaced the EGR with a happy block off plate thinking this was my problem, but it wasn't. It has a very recent tune-up, cleaned fuel injectors and oxygen sensor. By the way it doesn't throw any codes. Help please. Thanks
79 Cherokee 305 TPI
All Wheel Drive
6 inch lift
35 inch tires
3.54 Gears (Kind of suprised that it moves)
Old Mar 31, 2001 | 09:08 AM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
you blocked off the EGR and no codes? hows this?
Old Mar 31, 2001 | 10:59 AM
From what I hear when you block the EGR for some it throws codes, for some it doesn't. I can't explain it. I also pulled the EGR solenoid and rerouted the vacuum lines to eliminate that also, maybe that has something to do with it, I really don't know.
79 Cherokee 305 TPI
All Wheel Drive
6 inch lift
35 inch tires
Old Mar 31, 2001 | 11:42 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
You check all your ignition components? Plugs, wires, cap, rotor, coil, etc? Timing? sounds like lack of spark in a cylinder, maybe...sometimes bad wires work better than others, just because of the temperature. They expand and get better contact, etc...not common, but it does happen. That would explain the stumble under load, but not at idle. I had this problem.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
86IROC112
Aug 21, 2015 07:20 PM
Jake_92RS
Aug 17, 2015 09:42 AM
