Energy Suspension Trans mount.....
Old Mar 28, 2001 | 09:36 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Someone replied to my earlier topic concerning the bad vibs I'm getting through my car at 60mph+ and stated that they had the same problem when they installed an Energy Suspension Trans mount b/c the mount is actually taller than the stock which effects the pinion angle. Anyone else with a similar experience? The car vibrates & hums violently at 60+. I've swapped u-joints, driveshafts, balanced tires, etc.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Mar 28, 2001 | 10:02 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I have heard of this problem before...
I believe what most of the people i have talked to have done is to shim the trans crossmember to lower the angle...
1/8" or so is what you need to shim to get the angle back to proper alignment...
hope that helps,
Chris
Old Mar 29, 2001 | 10:01 AM
Beefy89's Avatar
I installed an Energy Suspension trans mount 2 weeks ago which fixed my clunking under hard acceleration,but now my Y-pipe is vibrating against the floor pan.I never thought about shimming it.I'll try it.
We need Perry Mason
Old Mar 29, 2001 | 09:06 PM
JohnnyIroc's Avatar
Car: 85 TA
Im having similar problems with my car and its really starting to get annoying, but the humming and vibrations start at about 75-80 in my car. I wish I could find the cure for this!!!!....someone told be it might be my rear end gears may not be set up perfectly, but I doubt thats the problem. Someone please help. Thanks
88 IROC-Z 305 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , TPIS 170* t-stat, Richmond 3.73 gears, March Power & Amp pullies, Home made Ram Air, Steve Spohn SFC's, LCA's , Panhard bar, TPIS AFPR, Ported plenum by Daniel Burk, Gutted cat
Best et: 14.232
Best mph: 97.76
Best 60': 2.063
http://hometown.aol.com/famioso15/johnnyiroc.html
Old Mar 29, 2001 | 09:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Humming and vibrations at 75+ MPH is caused by an out-of-balance driveshaft. Either get your stock one balanced, or buy an aluminum driveshaft.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 31, 2001 | 06:12 PM
Team FTS's Avatar
I had the stock rubber one...it ripped in half, then a steel one...center bolt kept coming out...I am currently using the enregy suspension mount the center bolt hasn't come out but the two side bolts did so the only thing holding it in is the single crossmember bolt
Old Mar 31, 2001 | 06:21 PM
98_1LE's Avatar
You can get a 1LE mount from SLP or gmpartsdirect.com for under $20. It is much stronger than stock and won't vibrate like the poly mounts. I have a 1LE mount in both of my cars and have yet to break one.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
bjpotter
Jan 22, 2019 12:27 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
Exxon Limited
Aug 9, 2015 08:13 PM
