LT1 Injectors
Old Mar 30, 2001 | 02:58 PM
Steve R's Avatar
LT1 Injectors
Do LT1 Injectors work on a TPI?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Mar 30, 2001 | 08:19 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Yes, I have LT1 24lb injectors in my ZZ4TPI set up. They work/fit fine. I would not recommend them unless you really need the extra gas. 22lb injectors are usually sufficient.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 30, 2001 | 09:17 PM
98_1LE's Avatar
Rob, what cam are you running? Do you feel that you needed the 24# injectors with a stock ZZ4 longblock and aftermarket TPI?
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 31, 2001 | 06:42 AM
Rob P's Avatar
Engine: ZZ4TPI
The ZZ4 is running the ZZ3 cam. Thinking back, I probably could have stayed with the 22lb injectors I had. I just wanted to be sure I didn't run lean and I got a good deal on the LT1 injectors.
So in the future when I upgrade to a LT4 Hot Cam and 1.6rr I'll be ready.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Mar 31, 2001 | 06:29 PM
Steve R's Avatar
Would LT1 injectors be fine on a stock 350? It's NOT an L98 - it's the 88 Impala motor in my '80, so it has a smaller cam and different heads. Mods are nice ignition, and headers. I plan to get this TPI swap done as soon as i get the fuel pump and lines.
Old Apr 1, 2001 | 08:52 AM
Rob P's Avatar
Engine: ZZ4TPI
Steve, maybe if you run an adj FPR and back the pressure off. What size did the motor come stock with? Probably 22s I would guess.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Apr 1, 2001 | 06:09 PM
Steve R's Avatar
This motor never came with TPI, only TBI. I just picked up a '86 complete TPI setup for it, and since i'm not going to go nuts with it, i'll probably just use the 305 injectors. The only thing that bugs me is that on the bottom of one of the injectors there was a small piece of plastic hanging down.. Oh well, first I have to have the intake drilled to fit later heads
New2Chevy
Sep 28, 2015 12:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
L0tuS
Sep 4, 2015 11:16 PM
