255lph fuel pump too much for stock FPR? Car dies after it warms up:(
Old Oct 15, 2007 | 11:25 AM
INSPECTOR 111's Avatar
HELP!!! 1991 Trans Am 305 TPI, dies after warm-up. I have brand new accel 19lb injectors.(all tested @ 14.9 ohms)
I have also recently installed a new gas tank with a 255lph fuel pump. I am still using the stock FPR, is it possible that too much fuel pressure is causing the injectors to fail after it warms up? Or will there just be some over run at idle?
Thank you for ANY help!!!!!
Frustrated, and holding a lighter,
Chris.
Old Oct 15, 2007 | 12:48 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 255lph fuel pump too much for stock FPR? Car dies after it warms up:(
Do you have a fuel pressure guage? Hook it up to the fuel rail and see what it reads.
And what happens when it "dies"?
Does it just quit? Or does it run really rich?
Old Oct 15, 2007 | 01:12 PM
The car just dies. It will turn over, but will not run or fire. (sometimes a little sputter)
This is only after it warms up.
I don't have a preasure gauge, but will get one soon.
Damn near everthing is new now. Is too much fuel bad or hard on the injectors? (other than running rich a idle)
Sometimes when it first dies, you can get it to start, but it will only idle like crap, and as soon as you even touch the gas it will sputter, miss, ping and shut down. Then it won't start untill it cooled down. (a long time. . . . . )
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
Kaweh
Aug 9, 2015 02:54 PM
