Newbie TPI questions
Old Apr 2, 2001 | 08:37 PM
Chevy SS-10's Avatar
Hi everyone. I have obtained a TPI intake for my S-10 V8 project. I will be using an Electromotive TECII to control it so my question pertains to hardware only. The intake I have is off of an 85 vette I believe. I think it has the cold start provisions in the runners. The aftermarket runners I've seen all say for 89 up or something like that. Now, can I bolt these runners to my older intake? Keep in mind, I don't need the cold start injector so I don't car if it won't work with that, but is there any other difference between the early and late intakes?
**edit**
One more question. I'm pondering building a 383 for this truck. I want it to be fast, but it will be daily driven and will tow my car. Can a TPI with aftermarket runners and ported plenum and base support 400 hp of 383 at less than 6000 rpm? Or am I wasting the shortblock with a choked down intake?
Thanks for your help.
[This message has been edited by Chevy SS-10 (edited April 02, 2001).]
Old Apr 2, 2001 | 09:59 PM
BP89IROC's Avatar
The parts will all bolt up the same, I'm not
sure about the egr stuff though with corvette versus camaro stuff. Shouldn't be a real problem with an engine swap project though.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, Hedman smog shorties, accel 8mm wires, made for you wire looms.
[This message has been edited by BP89IROC (edited April 02, 2001).]
Old Apr 2, 2001 | 10:36 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
The later runners will bolt on to the early base. Those wern't aftermarket runners you were looking at, were they? I don't recommend using aftermarket runners with a stock base or vice-versa. At least port the base and plenum while they're off. If you change one, change both. You'll need to have the PROM programmed to not use the cold-start injector, if it's and '88-earlier PROM. You'll also need a fuel rail that does not use one or plug the early type rail (where it exits for the cold-start injector). I never ran a motor without EGR, but I believe you can block it off and also program the PROM not to use it (regardless of year). TPIS sells block off plates, I don't know if anybody else does.
R3500
Aug 24, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
