what valve springs do i need to get ...
Old Apr 2, 2001 | 04:23 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I was thinkin bout running my zz9 cam... what valve springs do i need to get...
i would prefer not to have to have machine work done on the heads...
thanks,
Chris
Old Apr 2, 2001 | 08:09 PM
Nitro Don's Avatar
If you dont want the heads machined,then your limited to 1.250 springs.
As far as I know, K-Motion makes the best single H7 spring.Its a 1.265 diameter,.610 max lift,130-lbs at 1.700 installed hieght,and coil bind at 1.050.
Im going to be using these springs on WP heads with .544/.576 lift cam.
Nitro Don
Old Apr 3, 2001 | 09:22 AM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
sweet...
thats what i wanted to hear...
later,
Chris
Old Apr 4, 2001 | 05:33 AM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Nitro Don:
Nitro Don
</font>
If it was me, I would give the Cam manufacturing companies a call for suggestions. Springs with too much pressure can be "counterproductive" because the engine would have to make an extra effort to open the valves. The ZZ9 doesn't need too much pressure and eventhough NitroDon didn't mention open spring pressure, they sound like a bit of overkill. Besides that, if you have factory pressed in studs (like I do) you can kiss them good bye; they will all pop loose.
When I first put my cam in, I installed K-Motion springs and after 3 of them broke (Jeg's had misspelled the specs) I called Crower and fixed the problem. They are a bit mo' moni', but they are good quality.
Rick
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
