Painless wiring
Old Apr 2, 2001 | 01:23 PM
cobrakiller1989's Avatar
Painless wiring
has anyone ever used a painless wiring harness for a TPI car? what are your oponions on them? did it come with instructoins? was the installation easy?
thanks
Old Apr 2, 2001 | 07:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It blows goats. Installation sux. Painless is NOT for factory replacement, like you intend. I have personally used them to retrofit my LG4 to TPI, and if I had to do it again, Painless would be the LAST option.
Granted, it is an EXCELLENT harness, IF its a "Hot Rod" or other "custom" application. But if you are converting your Carbed or TBI F-body to TPI, its a "stock" conversion, and YOU WILL BE SORRY!!!!!!!!
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 3, 2001 | 11:12 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i have yet to hear any good come of someone using a PAINLESS WIRING TPI harness
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Apr 3, 2001 | 06:39 PM
Steve R's Avatar
I'm upgrading my 1980 to TPI. I was considering going with painless, only beacause the wiring harness i have now doesn't mark the injectors!! If not painless, what harness should I go with? Painless is pretty expensive, too
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Apr 3, 2001 | 10:15 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Steve R:
</font>
Doesnt matter what injectors you hook up where. Take your best guess.
As for Painless, they misnamed their product, it should have been Painful Wiring.
Old Apr 4, 2001 | 05:28 AM
Ski89Z28's Avatar
You may want to try these guys.
http://www.howell-efi.com/wiring_kit...tpi_index.html
I heard they are pretty good and will work with you if you have diffrent mods like trans.
Hope it helps.
Old Apr 4, 2001 | 07:11 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by madmax:
Doesnt matter what injectors you hook up where. Take your best guess.</font>
That's right, because TPI is a batch fire system, meaning all the injectors on one bank fire at the same time.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
