K&N/TPI AIRFOIL
Old Apr 4, 2001 | 09:12 AM
vanderspek's Avatar
K&N/TPI AIRFOIL
i have a 305 tpi engine in my 1987 Transam
i want to add K&N airfilter and TPI airfoil.
How much HP will i gain ?
Cor, The Netherlands
Old Apr 4, 2001 | 09:44 AM
jcyoung's Avatar
Vand, did the same thing recently to my GTA. You can notice some improvement, but it is not huge. As far as the horsepower improvement is concerned, I always take what the manufacture states and divide it in half. I would guess, no dyno information available, that the improvments added approximately 10 hp total. Good luck.
Old Apr 4, 2001 | 10:27 AM
formul8!!'s Avatar
Car: 2004 GTO
You will notice a little seat of the pants increase. The biggest difference will be sharper throttle response.
Old Apr 4, 2001 | 03:34 PM
KW87GTA's Avatar
I have these on my car too, you might notice a little difference, but like mentioned above the engine will probably respond a little better and it will breath a little better maybe resulting in better times. 10-15 hp but probably no more than 12. If you want to try and make a nice difference add some sort of cold air induction, modify your MAF relocat the MAT and you would feel some nice gains, and all can be done for a reasonable price. Good luck.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 4, 2001 | 10:01 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The more mods u do the more they will work with them.
Looking For:
87 IROC-Z28 350 TPI
The car I want.
84 TRANS AM 305 H.O.
Another car that would be OK to own while I still look for the IROC-Z!!
Old Apr 5, 2001 | 02:47 PM
IROCZ88's Avatar
You'll notice more with the K&N. Not much with the air foil.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
kairles
Oct 26, 2015 09:13 PM
vortech305
Aftermarket Product Review
Dec 5, 2001 02:01 PM
J's86ROC
16
Nov 14, 2001 11:42 AM
Camaro92
Mar 13, 2001 02:45 PM
hookin88formula
Oct 16, 2000 11:25 PM
