bad ignition module?
Old Apr 7, 2001 | 04:55 PM
dlp's Avatar
dlp
I had an MSD 6al box on my car for years but unhooked it after installing a new engine. After reinstalling it last nite my car would'nt even idle. I rechecked the wiring then removed it. Now it idles iradictly and has a bad miss while driving without the msd. I have a scanner but havent used it yet so any help will be apreciated.
87 IROC -
ZZ4 350
SLP T-Ram,1"3/4 SLP headers, Cat back, Hotch-kis, MSD, Iebach etc.
Old Apr 8, 2001 | 07:46 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
First, give me your T-ram!
I doubt its the module. Since you did a whole engine swap theres a million things to check. First and formost, check the plug wires again. Sounds like two could be crossed. If thats not it check ground wires (loose grounds play hell with computers), then reset the IAC and TPS.
If you think the module may be bad, take it to an autoparts store, they can test them.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
TheTraut88
Sep 11, 2015 05:16 AM
Amillionoh7
Sep 5, 2015 11:44 PM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
