Broken Knock Sensor?
Old Apr 9, 2001 | 11:31 AM
tommyred's Avatar
I noticed while getting my IROC out of storage that the knock sensor is broken off and dangling from the wire! the sensor itself is still in the block, but the plastic part is still in the harness, hanging down underneath. Anyone think I may be losing a few degrees of timing or any other problems from this? Thanks in Advance, I've learned a TON on this board.....
Hey! Skinny pedal on the right! (for those people that are ALWAYS in front of me!)
Old Apr 9, 2001 | 07:44 PM
ede's Avatar
ede
yeah i think it might be a problem. you might want to look into replacing it. if it's not leaking the easiest route might be to leave the broke part in the block and put a new senser in the other side and splice a piece of wire in the get the length you need to reach the new location.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 10, 2001 | 06:44 AM
tommyred's Avatar
Thanks for the quick response...actually the big round part of the sensor is still on the block too, so Im pretty sure I can get the whole thing out without bustin' the threads or anything....just the plastic connector broke right at the wire....I only drove it about 10 miles, and it seemed to run okay, but...one more question...the car originally had a 305TPI, now it has a Vette 350 TPI; do I need a different knock sensor? I believe the broken one is the original from the 305 setup.....
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
masonta
Sep 1, 2015 06:40 PM
