Is the Mini Ram worth the extra money???
Old Apr 11, 2001 | 06:20 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm going to build a 383 from an '89 350 block. I currently have a 305 TPI motor. I'm trying to figure out if the mini ram is worth all the extra money (well over $2k when all is said and done) or if I should just get some parts to upgrade my TPI. If I upgrade my TPI then runners and a manifold are definite, and I'll either port the hell out of my plenum, or get the superram plenum. I know the mini ram flows better up top, but is it really going to be worth it? I could put the extra money into better heads. I'd really like input from people with the mini ram, or upgraded TPI setups, especially if on stroker motors. I plan to run between 9.8:1 and 10.2:1 compression, with most likely Trick Flow or AFR heads, a decent sized cam, as well as a 6spd, and 3.42 rear. Please advise. Thanks
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
Old Apr 11, 2001 | 09:44 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Do a search on MiniRam. You'll get more information that you bargain for. You are WAY off-base about $2K. That number is totally off. MiniRam + Fuel Rail Kit = $895 + $295 = $1190. Where do you get $2K??? Don't even think about counting the cost of a PROM because no matter what you do you will need a new PROM. I 'decent sized cam' and a 'good set of heads' will require a significant PROM change no matter what intake you run.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Apr 11, 2001 | 10:48 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Yeah, I know I won't need the prom, forgot that while reading their page. They also say that I'd need their wiring harness, or that's how they make it sound, but I don't think that's true now. I did do a search on the mini ram, after I posted though, and I think I have to go with aftermarket TPI, because there's no EGR on the mini ram, and I live in NY. But thanks for the help
J-money
Jan 4, 2019 09:45 AM
Stangski09
Nov 14, 2015 01:27 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
09ave
Sep 7, 2015 06:03 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
