Idle Issues - Help
Old Oct 25, 2007 | 11:01 PM
92RTripleS's Avatar
Car: 92 RS Convertible
Engine: 383
Transmission: 700R4 Streetfighter
Axle/Gears: 3.73 posi
Idle Issues - Help
my car does not want to idle at all. i dont know if the idle air controller is putting the rpm's too low or what but everytime i let it idle, it surges and goes up and down a few times then just cuts out and dies. so how can i bump the idle up a little so it doesnt cut out and die on me? also would the fuel pressure being up high do this? the pressure is around 50 psi right now which is way to high i know, but i cant change it til i get a hold of my friend's fuel pressure gauge.
thx
Old Oct 26, 2007 | 09:16 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Idle Issues - Help
I would check for vacuum leaks, if no leaks I would do this:
https://www.thirdgen.org/tpimod2
Old Oct 26, 2007 | 11:48 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i agree....sounds like a massive vacuum leak. check all your hoses in case one fell off to start with.
Old Oct 26, 2007 | 12:01 PM
92RTripleS's Avatar
Engine: 383
Ok, ill be sure to recheck for vacuum leaks again
thx
Old Oct 27, 2007 | 02:24 PM
92RTripleS's Avatar
Engine: 383
turns out it was a bad IAC. i just replaced it and its working just fine now... well at least right now it is. i think the old one kept sticking
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
