should it?
Old Oct 27, 2007 | 02:21 AM
85s10tpi's Avatar
Car: 88 gta 305 tpi in a 85 S-10
Engine: 88 maf LB9 T.P.I.
Transmission: 700r auto st.2 kit
Axle/Gears: stock 3.44 s-10 diff
should it?
after I set my tps voltage to .65 volts today i tried adjusting the idle a bit. when i grounded the a and b terminals and waited the 30 seconds i fired it up and in order for me to keep it runing i had to give it a fair about of gas is this normal? after i lowered the idle a bit (while giving it gas) and reset the computer it idled lower which is what i wanted. is this a sign of a vacuum leak?
thanks in advance
Old Oct 28, 2007 | 10:18 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: should it?
reset your tps to .54
.65 is too high. could explain your idle issue.
