86 305 TPI Trans Am
Old Oct 27, 2007 | 05:21 PM
Mantisx69's Avatar
86 305 TPI Trans Am
ok, bought another car, a 86 Transam with 305 tpi. didnt have fuel, but would idle if i sprayed gas in the throttle body. Needed a water pump changed before i started on the fuel pump. changed the water pump, didnt unhook the battery like i should, (Stupid Me) and as i was relining up the alternator it grounded out a pipe by the throttle body. sparks and all that happy fun. well now i have no spark. checked the coil and the ignition module at 2 differant autozones. one even ran the tester on the module like 10 times, all green lights. both are good i guess. brother ran his 89 gta on my computer with his prom, so the computer is fine. i need to really get this car sparking. so if anyone could let me know what would possibly have gotten shorted out that i need to replace it would really be helpful.
thank you
Old Oct 27, 2007 | 10:21 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: 86 305 TPI Trans Am
Umm, distributor?
Do any other electronics work?
Old Oct 27, 2007 | 10:55 PM
Mantisx69's Avatar
well the radio works, starter, gauges work. everything else works just fine, just no spark.
Old Oct 27, 2007 | 11:12 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Do you have access to another distributor?
It seems to me that the distributor is the only thing that you haven't checked.
Alternator could have died to, but I don't think so if all your other electronic things work...
Old Oct 27, 2007 | 11:33 PM
Mantisx69's Avatar
no acess to a spare disty. brothers gta is a differant style. only choice is auto zone i suppose.
the alternator would stop me from having spark?
Old Oct 27, 2007 | 11:39 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Yeah, I love how the earlier TPI motors had special distributors...not sure what the morons at GM were thinking then...
Old Oct 28, 2007 | 11:13 AM
Vader's Avatar
Is there power to the distributor (pink/black wire) with the ignition ON? You may have cooked one of the fuse links during that alternator incident.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
