Coolant fan switch sensor disconnected
Old Apr 15, 2001 | 02:32 PM
Casey'91Z28's Avatar
When I was putting my headers on I guess I broke the connecter to the fan switch sensor(the one on the head on the passenger side). I have left it disconnected, my temperature guage doesn't work, is this bad at all for my car. I have yet to have the SES light or check engine light to come on. Where can I get a new connecter for the sensor? Could I just buy a hypertech or jet fan switch to fix it(do they come with a new connecter or just a sensor)?
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, SLP 1 5/8" headers, catco 3" cat, 14.7@ 93 mph.
Old Apr 15, 2001 | 02:54 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I could be wrong but I don't think the Fan Switch is going to make your gauge stop working! The gauge sending unit is in the head on the DRIVERS side and controls the temp gauge in the car! The sensor in the head on the PASSENGER side just controls when the fan kicks on and off! Check the sensor in the DRIVERS side head and make sure you didn't break that one too or that the wire didn't come loose!! Mine comes off sometimes while changing spark plugs so that's likely!
As far as replacing the connector for the fan switch! Next Gen Parts sells lots of connectors! Take a look at www.nextgenparts.com to see if they have what you need!!
Old Apr 15, 2001 | 03:14 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Dont buy any connectors. I go to the local junkyard with wire snips in hand and go to work on the GM cars.
eightsixseven
Dec 16, 2024 01:50 PM
Bstrang6
Sep 8, 2015 04:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TheExaminer
Aug 26, 2015 04:59 PM
TA8487
Aug 16, 2015 12:21 PM
