slp runner
Old Apr 15, 2001 | 12:45 AM
chrisandkristin's Avatar
slp runner
everyone says that u have to change your cam to see an improvement when u use slp runners .......... if i put intake manifold headers and exhaust on it will even it out or will i be ok with a stock cam ordo i have to get a bigger cam any feed back would be great
Old Apr 15, 2001 | 06:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The SLP runners work better with a larger cam.
I'm moving this to the TPI forum.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 16, 2001 | 05:14 AM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
Well. I'll be damned. Isn't this the TPI fourm? Why do you, moderators keep saying "I'm moving this to the TPI forum"?
Ede did the same with another post. Am I going crazy or are you going crazy or my car backfires&*(HNN ,mnk44
yes sir.
loVe u, by by
Old Apr 16, 2001 | 12:12 PM
jRaskell's Avatar
The original post was created in a different folder and the moderator moved then ENTIRE thread to the TPI folder (It actually was just copied to the TPI folder and then locked in the folder it was originally posted in. From here you just don't see where it was originally posted.)
As for the original question, I think the specific answer is that you will see a bigger gain with the right cam, but it is still possible to see some small gains with the stock cam (moreso if you upgrade the runners and the base, the intake base being the most restrictive component in the intake)
Old Apr 16, 2001 | 01:31 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i've heard a lot of people recommending going with a higher stall converter as well
Originating member of the SJNEP Crew "Welcome to Understated Sounds and Performance"
Rice..It's whats for dinner!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Tony
Check out www.transamgta.com
"What does not kill us only makes us stronger"
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
