Question for people with 87 TPI and SLP Runners
Old Apr 16, 2001 | 05:19 PM
Jas89TTA's Avatar
Well, It might be the same set up on other cars also. What I got is a 87 TPI V-belt system with SLP runners and on the stud that goes on the right front lower runner that the Altanator bracket mounts to will not go all the way down with the SLP runners it hit's the side of the runner. I've trid grinding the stud some but it still hit's and if I grind any more I won't beable to get a wrench around it. There's not even enough clearence for a s****et wrench to fit between the runner and bolt. Did anyone else have this problem? If so what did you use?
Old Apr 16, 2001 | 09:40 PM
87IROC350's Avatar
Engine: 5.7
I made a spacer to go between the slp runner and the alt bracket. Then I purchased and allen head bolt and threaded in no problem. The problem that I had was if I didn't use the spacer the bracket tightened down at an angle putting it in a bind.
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners (matched intake-runners-plenum), 48mm TB, 6E(arap) chip, Vigilante & Probuilt trans.
Old Apr 17, 2001 | 07:08 AM
Jas89TTA's Avatar
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
