wondering if i can use my MAF tpi setup to convert it to MAP?
Old Apr 18, 2001 | 05:44 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i have a complete TPI setup from an '89 IROC i'm parting out..
I want to put it in my '68 Camaro, but the way I want to set it up I will need a MAP-style TPI setup in order to match my hood..
I've been told it's possible to 'changeover' a MAF setup to a MAP one?
I want to do it, but if it would make the TPI unreliable, run in open loop, or have to monkey with cutting wires I don't want to do it..
thanks,
Colin
Webmaster: www.IROC-Z.org
Old Apr 18, 2001 | 07:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's a tech article on doing it. It does involve a lot of re-wiring unless you get a 1990-1992 wire harness.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
