tpi question
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
tpi question
my question is about fuel lines. i have an 88 305 tbi with a serpentine belt system. the tpi unit i picked up was from an 87. i dont know if it was from a serpentine belt system or not. the fuel lines on the tpi unit come out underneath the throttle body. is that were its supposed to come out at for a serpentine belt system. the reason i ask is because i have that the fuel lines are routed differently for the different belt systems.
Car: 1988 firebird
Engine: 305 tpi
Re: tpi question
i know this might be a dumb question and all, but need a lil help with it. its an 87 tpi. i have serpentine belts. will there be any feed line issues?
Car: 1985 Camaro Iroc-Z
Engine: 5.0 TPI
Axle/Gears: 2.73 posi
Re: tpi question
From what I understand, the Camaro TPIs fuel lines came out the driver's side below the throttle body. The 85-86 Camaro Iroc Z were a combo of Serpentine and V belt. They have unique brackets for power accessories. I believe the Corvette TPIs came out the opposite side.
Car: 92 Z28
Engine: 357 TPI (L98)
Re: tpi question
I've got a 92 TPI. Mine come out right under the throttle body, then turn hard and go behind the alternator (drivers side), then back down toward the body.
Did that answer your question?
Car: 1988 firebird
Engine: 305 tpi
Re: tpi question
yes that did answer my question. thank you very much. i feel better now. because i thought i would have to fab up some fuel lines or something. because i have an 87 system going on an 88 car with serpentine belt system.
Sanjay
Aug 12, 2015 03:41 PM
