HELP ME with my tpi hesitation prob please
Old Apr 18, 2001 | 08:37 PM
bad camaro RS's Avatar
my hesitation seems to be getting worse when i first started notice it it was only if i got on it off an idle now jus about anytime i hit the gas fast it cuts out and sometimes if i punch it to the floor real fast i can have the pedal on the floor before it takes off ive check my tps ive had it from .54 to .62 and it changes nothing ive reset my iac could my maf be getting slow? any ideas would be greatly apprecated thanks
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 18, 2001 | 08:52 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
while the car is at idle lightly tap the housing of the maf if the engine stumbles your maf is burning out.also check the tps just because you're getting the right voltage at idle doesn't mean that it's correct at off idle open the throttle blades with the engine off and check the tps voltage at w.o.t if i'm not mistaken it should go to 4.0 but check this sight i'm sure there's something on it.
Old Apr 18, 2001 | 11:25 PM
89bonestockiroc's Avatar
I had that problem for a while too. Mine was real easy though, i had bad plugs or wires. I did a complete tune up including wires, plugs, cap, rotor, and even the coil. One of those things fixed the problem. Im not really sure wich because i did them all at the same time.
Old Apr 19, 2001 | 03:36 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I had all kind of problems like this. I replaced practically everything. Turned out it was a bad connections at the TPS. The computer wasn't getting the voltage reading from the TPS all the time. Mine threw a TPS code a few times, but I couldn't figure it out. It was a bent prong on the connector. I'd check this for sure!! I ended up hooking a scanner up and seeing that the TPS volta would be at 0 sometimes!! Hope this maybe helps!
*TAp your MAF like they said also, and do a tuneup (plugs/wires/cap/rotor/fuel filter/etc) This helped mine a ton.
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Apr 20, 2001 | 11:53 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I had an odd experience with this on a friend's '89 IROC...the thing would stunble like hell...use my air hood and MAF...no fix...my relays and IAC...no fix..reset the TPS...no fix...turns out I checked the TPS at the sensor and it was .54 at idle, 4.35 at WOT. BUT I connected a scan tool and it only showed .8 something at the sensor (wierd it didn't set a code...maybe the intake mods)Keep in mind the computer was telling me the .8 figure. Since it was .54 at the TPS, I can only assume that there is a voltage loss somewhere between the TPS and ECM...I ended up replacing the connector. If you can, get a GM Tech 1 or something like that to read the ECM, it helps. Hope this helps someone...
84z96L31vortec
Aug 20, 2017 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
