Which Fuel Pump Should I Use / El Camino
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Putting a TPI 350 into an 87 El Camino, need to know which fuel pump to use?
Frame mount?
Change gas tank?
Thanks,
Dave
Frame mount?
Change gas tank?
Thanks,
Dave
Guest
Posts: n/a
Re: Which Fuel Pump Should I Use / El Camino
All depends on your preference. A frame mounted pump is easy to upgrade or replace, but they're kinda noisy. Finding a baffled tank with the intank pump (Regal, Monte) and sender might prove costly although since you dont have a spare tire well there's supposedly a mid 80's Caddy tank that'll work.
Which frame mounted pump do you like?
It's a pretty stout 350 with 30lb injectors.
Guest
Posts: n/a
I was using the Accel pump for a while. Well... what they sell is a Bosch pump, thats for a mid 80's Porsche 928 with the outlet fitting already tapped for a NPT thread. It was a little noisy. I have an intank now, from a Turbo Buick. Some kind of high flow Walbro in there. Seems to be keeping up with my 30's just fine.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
check out gbodyforum.com and most
G body guys like the inline. It's easiest and cheapest. I had an 84 conquista with black and red paint. I miss mine so much!!
and make sure you get those SFC's ha ha ha!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
