Gutting dual cat setup..who here has done it?
Old Apr 20, 2001 | 12:03 PM
theformula's Avatar
Looks like my cats are clogged. I need some advice or tips on how you guys gutted the dual cat setup. I cant afford to spend the $275 for a catco dual setup from Summit
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 20, 2001 | 12:16 PM
jobryan26's Avatar
Try the Exhaust Link at the front of the Message Boards.
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Old Apr 20, 2001 | 07:42 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
if you can unbolt the catback & look directly into the mufflers you can take a crowbar & break up the material inside. Every once in a while crank the car & rev it to blow the chunks out. If you can't do it like this I have no idea.
Old Apr 20, 2001 | 09:55 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Gutting the dual setup is close to impossible. I have SLP headers with the dual cat setup and I made it so that my stock GM converters are slipfit. I have one set that I gutted and one set that are relatively new. Gutting them AFTER I separated them from the dual cat assembly was easy. But, I can't see how you would be able to gut them while still in the assembly. You would have to chop them out of the assembly with a sawzaw, gut them, and then weld them back in.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
