vortec heads on TPI
Old Nov 1, 2007 | 10:13 PM
dberry's Avatar
Car: 89 Firebird Formula 350
Engine: 5.7 liter 350 tpi
Transmission: 700 r 4
vortec heads on TPI
will newer model vortech heads work on a 350 tpi motor???
just need some info thanks
Old Nov 1, 2007 | 11:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: vortec heads on TPI
Yes but you need to get the Scroggin Dicky TPI Vortec intake manifold.
Old Nov 1, 2007 | 11:42 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
scoggin dicky vortech TPI base will run u 400$.... could use some porting if u want more HP, and u need the remote EGR tube etc.... not sure wat that will cost u, vortech intake gaskets, vortech intake bolt kit
Old Nov 1, 2007 | 11:53 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
what the heck is the remote EGR tube??
Old Nov 2, 2007 | 12:02 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
All the information you could want and more. You can sometimes find these manifolds for less than $200-250 on either the Classifieds, Craigslist, or Ebay.
http://www.sdparts.com/pdf/TPI_instruc.pdf
Old Nov 2, 2007 | 01:51 AM
Car: 87 TA clone
the head doesnt have an EGR port casted into the head, they block it off like most popular aftermarket heads, the stock heads and sum aftermarket heads have this port which utalizes the EGR under the TPI plenum that recirculated the gases crank, valve cover gasses etc back into the engine to be burned for a cleaner emissons... the vortech heads dont have this and require a special metal tube that plums the EGR gases so that the head/vortech baseplate can be emissions legal. look at scoggin dickey etc they have pics of the tube i believe.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
