Injector Possibly bad
Old Nov 5, 2007 | 07:16 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Had some plug problems...although I thought. Changed plugs recently. car had been running rough (missing) on idle when warmed up. Finally after changing the plugs within 4 minutes we had a miss on #8. Checked plugs before I had new ones, and noticed 8 was verydark and wet. Started her up and pulled the injector wire on #8 and it was the culpret. Measured Ohm reading. all the rest were 17. However the #8 injector gave me a 4.6 Ohm. Sounds like a bad one.... The big question is, should I change them all, due to the fact that I will need to take off the plenum. Or should I just change the one. BTW I think that fuel additive called Guarrantied to pass may have done that injector in.
injectors are 18 yrs old.
Old Nov 5, 2007 | 07:26 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Injector Possibly bad
those injectors are garbage, get a new set of SVO injectors
Old Nov 5, 2007 | 07:29 PM
Axle/Gears: 373s
Right now I'm trying to pass Cali's smog check. Where is the best place to look? I'm not trying to get more horsepower, I just want 22LB injectors.
Old Nov 5, 2007 | 07:38 PM
QuickStyle's Avatar
Car: 91 Z28
www.summitracing.com sells SVO injectors. but if you just want one injector to replace the one that is bad on your car, i have like 3 sets of 22lb stock injectors. you can come pick one up if you like, im right here in Bakersfield.
Old Nov 5, 2007 | 07:48 PM
Axle/Gears: 373s
Excellent. I work in Bakersfield. I will PM you with the info.
Street Lethal
Apr 30, 2019 12:14 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
