TPI runners/plenum install.. will not align correctly, why?
Old Apr 25, 2001 | 11:37 PM
MrJ's Avatar
MrJ
It's very odd. I can install both runners loosely, and when I drop the plenum between the runners to bolt it in, I can't get damn thing to line up. It will line up fine on the driver's side, but on the pass. side it wants to sit crooked. I've spent about 5 hours so far on this with no luck. I've tried every method that I can think of. When I was removing the pass. side runners, I didn't know that there was that one bolt that had to be accessed from the opposite side, so I pryed the hell out of the runners in an attempt to remove them. I think this may be part of my problem. What can I do to get all this stuff installed?
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Apr 26, 2001 | 03:39 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Pray!
Old Apr 26, 2001 | 04:39 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
you pryed??
*tisk tisk tisk* you forget the whole TPI setup is soft aluminum...
Webmaster: www.IROC-Z.org
Old Apr 26, 2001 | 08:36 AM
MrJ's Avatar
MrJ
Looks like the sledgehammer is gonna become my best friend...
Old Apr 26, 2001 | 09:22 AM
72BuickGSX's Avatar
hehe yeah its a bitc# i had problems with mine untill i realized that the bolts are diffrent lengths , so when we worked on my cousion 89 formula i keep everything exactly the way i took it off and and it went back on fine, hope this helps
Old Apr 26, 2001 | 10:51 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i know this may be a stupid question but are you putting the runners on the side that they are supposed to be on?they are both different!
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Old Apr 26, 2001 | 11:23 AM
MrJ's Avatar
MrJ
of course they are on the right sides. The one with the small extra tube goes on the passenger side, the other on the driver's side.
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
383backinblack
Aug 15, 2015 06:36 PM
Sanjay
Aug 12, 2015 03:41 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
